dodge 100 pickup question?
hey guys i have a AT4 pickup with a 245 hemi in it. but i wanna put a 360 in her, anyone know what is to be done to make this work? by the way im in australia so i dont know if its called something different in other countrys.
I believe the AT4 is an Aussie design... probably has either a carryover chassis from the earlier trucks and vans or similar...
Body, as you know, was shared with International.
There are plenty around with V8s, there's plenty of room for a V8 in there. You will face choices about which flywheel size you use, and the bellhousing. Is yours fitted with the A745 gearbox? If so, you'll be looking for a car-size flywheel and bellhousing to suit.
Not impossible, but thin on the ground.
e.mail me if you want more info.
