What transmission fluid for 1980 Aspen?
Old Jul 23, 2006 | 05:31 AM
mickclark8's Avatar
mickclark8
Default What transmission fluid for 1980 Aspen?
I have put 1980 Dodge Aspen running gear into a 1937 Dodge D5 Sedan.
It is a slant 6 with a torquflight transmission. What transmission fluid currently available is best for this transmission?
Will the new Mopar ATF+3 work? Would it work better and enable the transmission to last longer then the original trans fluid?
Old Aug 9, 2006 | 03:44 AM
HemiPoser1979's Avatar
HemiPoser1979
Default RE: What transmission fluid for 1980 Aspen?
I have a 1979 dodge aspen with a 225 super six or slant six use dextron type pennsoil has worked great for me!
Old Aug 11, 2006 | 10:22 PM
dodgetkboy78's Avatar
dodgetkboy78
Sure, it wil work just fine.
If you want superior fluid, go with a synthetic.
Old Jul 15, 2007 | 08:19 PM
moe7404's Avatar
moe7404
Moe in Wichita,KS. For long trans life put in 2 qts of rear end grease. it will shift a little tighter. do this only on the older tourqflites. it may or may notbe ok on the newer trans. i have put one qt in my 1999 dakota v 6 so far so good. this is an old drag racers trick
