Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
how to identify my transmission?
Old Sep 7, 2004 | 05:34 PM
Call me trinity's Avatar
Call me trinity
Default how to identify my transmission?
I've got a 1993 Dakota 3.9L with a automatic transmission, long box, regular cab. The transmission is starting to give me problems. When it is cold it goes into gear o.k-when I accel. then back off the gas then reapply the gas it acts like it is in neutral-revs up then jumps into gear. It will do this a few times at first(first and second gear).Once it warms up this problem stops but the on going problem is the erractic shifting from 2 to 3. some times it shift normal and sometimes it hangs in 2 then at high rpms shifts in 3 then into overdrive. Oil level is fine and I recently changed the oil, installed new filter. Got the oil from Dodge-ATF+3. Probably first time changed in trucks history(200,000 kms).
[X(]
Getting back to my question-How do I determine the type of auto trans. that is is installed in the truck?[
Old Sep 8, 2004 | 04:14 AM
dodgemech's Avatar
dodgemech
Default RE: how to identify my transmission?
It has a 42RH. Check your fluid level, sounds like its low. Make sure you check it idle in neutral on level ground. The fluid level should be in the middle of the crosshatch, NOT the top or the bottom, in the middle.
Old Dec 13, 2004 | 07:16 PM
fade2blk500's Avatar
fade2blk500
mines got 225k miles and it's been having the same problem for over 50k miles. i just let it warm up good before i leave.
