Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
ABS Light
Old Sep 17, 2004 | 05:04 PM
1967gto's Avatar
1967gto
Default ABS Light
I have a 1999 Dodge Dakota, that has devoploped a faulty ABS and Brake light. All the system apears to be working but the lights remain on. I am in the UK and have little acsses to US systems here. has anyone got a 99 wireing diagram that could be posted???? or Emailed????? or any ideas
Old Sep 18, 2004 | 01:22 AM
dodgemech's Avatar
dodgemech
Default RE: ABS Light
You are not going to be able to fix it without access to a scan tool to pull the fault. DO NOT TRY TO FIX THIS ON YOUR OWN. If you mess with the system, then when a tech tries to figure out what is going on all the data will be lost.
Old Sep 20, 2004 | 06:30 PM
Mr. Mustard's Avatar
Mr. Mustard
Same thing happened to my 99 dakota. Ended up replacing the brake control module ($480). It needs to be programmed with rear diff. and wheel info.
