Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Removing the 4x4 stickers
Old Jul 5, 2007 | 07:33 PM
Snikkari's Avatar
Snikkari
Default Removing the 4x4 stickers
Greetings fellows.
What is the best way for me to remove the 4x4 stickers at back without leaving a mark.
heatgun or hot water, or just peel off cold ?
plz comment,
Old Jul 6, 2007 | 12:01 AM
jonnymagnum's Avatar
jonnymagnum
Default RE: Removing the 4x4 stickers
I would try a heat gun, or leave it out in the sun and let it get nice and hot. then peel it off.
you might have to buff/wax it. it depends how faded it is.
Old Jul 6, 2007 | 05:07 PM
fbnzippy's Avatar
fbnzippy
Heat gun/ hair dryer. Then WD-40 to remove the residue
Old Jul 7, 2007 | 09:27 AM
superdak05's Avatar
superdak05
lightly go over it with a hair dryer. then once it is soft simply remove it slowly. if the sticker has been on for years then the 4 x 4 stain will be there. if you get lucky and its not there then take some wd- 40 on a rag and rub the area untill all the adhesive is gone. then give it a good washing and waxing and you will be good to go
Old Jul 12, 2007 | 02:19 PM
griffster36's Avatar
griffster36
Would this same technique apply to those window air deflectors that go around the passenger and driver side door windows?
Old Jul 12, 2007 | 06:21 PM
klings designs's Avatar
klings designs
For the air deflectors, I would let it sit in the sun, then pull off, then you just have to get all the residue off! WHICH IS A PAIN!
Old Sep 11, 2007 | 10:01 AM
Brymac76's Avatar
Brymac76
Ya I second that Klings...that residue is a huge pain to get off. Took me like 3 hours to get it all off. I didnt use WD-40...i used Goo Gone...not sure is better. Didnt really know you could use WD-40 like that. Wish i would have tried it now.
Good luck with the stickers if you aint done already.
Old Sep 18, 2007 | 10:00 PM
RJTDakotaBoy's Avatar
RJTDakotaBoy
I peeled mine off cold and then used WD-40 to get the residue off. It was awesome
Old Sep 18, 2007 | 10:06 PM
SrtHemi's Avatar
SrtHemi
Also if you are confident in your self and your vehicle has base/clear on it you can use mineral spirits---or if you are really good use thinner, but if you use any of those make sure to wash it afterwards and wax.
