Anyone know how tight in ft/lbs the rear diff cover bolts should be on my 8.25 differential? I am getting a small drip (very slow) and would like to try tightening before removing the cover and resealing.
better to remove the cover. at that age its probably time to change the fluid and re-seal anyways. dont over-tighten to the point the bolts will be stripped when you have to remove them next
