Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
ball joints II
Old Jan 10, 2004 | 01:43 AM
dakotadigger's Avatar
dakotadigger
Default ball joints II
after reading the entry ball joints,I posted a comment about them. I have been noticing that the steering has started a popping every time I turn all the way to the left or the right. is that normal, i don't think so. any advice on what i should do. The truck is a QD cab 4x4, 2000 with eng 4.7ltr</P>
</P>
Thanx, Pat</P>
</P>
Old Jan 11, 2004 | 09:26 PM
phantumhawk's Avatar
phantumhawk
what size tires do you have, if your tires are to wide the can rub on your fender wall which would also cause a popping sound depending on how aggressive of a tread pattern you got. this is only the case when you turn full in either direction probably more in one direction because of alignment.
