Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
oil leak? dakota
Old Feb 16, 2008 | 03:12 PM
drpd99dak's Avatar
drpd99dak
Default oil leak? dakota
took it to a friends dad place and he's a mopar mechanic..anyways said there is a small leak coming from the back of the intake and said it would cost somegood money to fix.has anyone ever had this problem with thir 98-^ dakota's?
Old Feb 16, 2008 | 03:37 PM
Truck Dude's Avatar
Truck Dude
Default RE: oil leak? dakota
well not exactly, but mine was leaking from the valve cover gasket...it took some time to find the leak because it was small and in the back somewhere, but it would drop on the starter, header, and steering shaft. new valve cover gasket fixed it.
Are you positive its coming from the intake?
Old Feb 16, 2008 | 03:51 PM
drpd99dak's Avatar
drpd99dak
pretty sure. before it hits the ground, the last spot its on is the bottom on the trans
Old Feb 16, 2008 | 08:39 PM
Truck Dude's Avatar
Truck Dude
yeah, leaks like those on the back of the motor are hard to diagnose, at first i thought i had a blown head gasket, but i cleaned the block off with brakleen real good, then started it up and got in there with mirrors and things to try to see where it was coming from.
Hope i helped atleast a little, goodluck with finding and fixing the leak!
Old Feb 17, 2008 | 12:25 AM
drpd99dak's Avatar
drpd99dak
so you think it's probably the valve cover gasket?
Old Feb 17, 2008 | 12:42 AM
OneBadKota's Avatar
OneBadKota
ORIGINAL: drpd99dak
MOST of the time, a rear leak is the valve cover gasket. However, I would keep an eye on the intake as well. It could be a rear main as well.
Old Feb 17, 2008 | 01:02 AM
drpd99dak's Avatar
drpd99dak
yeah im expecting it to be the intake more than the valve cover
Old Feb 17, 2008 | 01:56 PM
Truck Dude's Avatar
Truck Dude
im not saying it is the vavle cover gasket, im just giving you what happened to mine to try to help..it sounds like its further back on the engine then mine was...
