Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
A/C / Heater fan works Intermittently
Old Jan 2, 2005 | 12:04 AM
odellcash's Avatar
odellcash
Default A/C / Heater fan works Intermittently
I have a 2000 Dak, and the a/c fan will work in the morning for about 10 minutes than go off. Sometimes it will come back on for a minute or two. Other times it seems to be running, but slow.
Is this a motor problem, or something else?
thanks for any help.
Old Jan 3, 2005 | 04:07 AM
injmopar's Avatar
injmopar
Default RE: A/C / Heater fan works Intermittently
The blower draws a high current,so all it takes is a bad or loss connection to cause intermiten problem. Check the ballist resistor plate connector,or the ground on the stearing colum mount bolt
Old Jan 4, 2005 | 02:10 AM
odellcash's Avatar
odellcash
I will check this out.....thanks
