Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Water under pass. carpet
Old Apr 6, 2008 | 11:53 AM
slidekid34953's Avatar
slidekid34953
Default Water under pass. carpet
For some reason I am getting water under carpet on passanger side. It looks like clean water.Does not look like it hasany anti-freeze in it. Help please
Old Apr 6, 2008 | 07:15 PM
OneBadKota's Avatar
OneBadKota
Default RE: Water under pass. carpet
Does it smell sweet? If so, it's anti-freeze and would be the heater core.
If not, it's more than likely a leak from the weatherstripping somewhere.
What type of vehicle is this on? Dakota? Sliding-back window? Ext. Cab?
Old Apr 8, 2008 | 01:38 AM
geoffb123's Avatar
geoffb123
I get the same thing on the drivers side. But ONLY when i have a floormat down. Im still stumped to this day.
Old Apr 9, 2008 | 08:25 PM
Freebird's Avatar
Freebird
Hello, Im new here, but I used to own a 96 Dakota and I had the same problem. It turned out to be that the tube that all of the A/C condensation came out of from under the truck was clogged. Whenever that was clogged it would back up and just dump out into my passenger side floor, never the driver's side for some reason. Anyways, running a coat hanger or small diameter wire into it will do the trick. Just be prepared for all the water that comes out.
I hope that this helps, it may or may not be the problem, but it sounds an awful lot like what I was experiencing.
