Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Stripped Dakota Brake Caliper Bolts
Old Jan 21, 2005 | 11:03 PM
Mikemomd's Avatar
Mikemomd
Default Stripped Dakota Brake Caliper Bolts
Any suggestions to take care of stripped threads on the brake spindle of my 94 4WD Dodge Dakota...I replaced the bolts with new ones but the receiving threads on the female side are stripped. They are the lower ones on both front sides that someone else screwed up after a DIY job. Do they make oversized caliper bolts for this situation? Any other possiblities?
Mike
Old Jan 24, 2005 | 07:25 PM
Dodgeguytoo's Avatar
Dodgeguytoo
Default RE: Stripped Dakota Brake Caliper Bolts
You could possibly put in a helicoil and put in a new bolt. Smaller size I suppose but it would work. Check into helicoils. Or start tapping new threads.
Old Jan 28, 2005 | 01:52 AM
injmopar's Avatar
injmopar
Putting in a helicoil will make it stronger than the threads in the casting if there is meat left to install the coils. I pulled the threads out two boltholes on each of my aluminum calipar brackets. After putting in 4 coils ,I never had a lose one. Every two weeks they use to pull me down from 144 mph.
Dodgeguytoo I can't beleave you put a rampage scoop on a 87 Dakota.....Dam......
mine is still hanging on to shop wall .Is it to the back or front. Post a pic
88 Dakota Mag 318 std cab short box
Old Mar 5, 2005 | 01:36 PM
Rick980's Avatar
Rick980
had the same issue with my 98 dakota sport only on the drivers side, drilled it out and put a helicoil to match the thread of the original caliper bolt. It was an odd size. i forget actually what it was but I know it was hard to find.
Old Mar 19, 2005 | 11:07 PM
914dakota's Avatar
914dakota
I believe the size is 9 mm. The local NAPA store had it here.
