Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Cold temps
Old Jan 26, 2005 | 08:13 PM
NLRfireman's Avatar
NLRfireman
Default Cold temps
It takes awhile for my 95 Dakota with 77,000 miles to warm up. I've replaced the Thermo,water pump, belts and hoses. Heater core does not leak. Also it only blows luke warm air on low fan speed. If I increase the fan speed it will only blow cold air.
Need help
Old Jan 27, 2005 | 03:06 PM
Narcisse91's Avatar
Narcisse91
Default RE: Cold temps
What's "awhile"?
Old Feb 2, 2005 | 11:15 PM
BlueDak's Avatar
BlueDak
I would have the cooling system flushed, maybe pull the radiator and have it rodded out. Then go through it again, coolant mix proper? new thermo, etc. Also, have you replaced the temp. sensor?
