Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
92 dodge dakotas v6 runs then shuts off
Old Jan 22, 2009 | 10:41 PM
alabama_kush's Avatar
alabama_kush
Default 92 dodge dakotas v6 runs then shuts off
I have a 92 Dodge Dakota that will run fine for a short time , then
stalls at running temp after sitting for some time it will crank, engine will turn over, there fuel at the rail, it will only crank if both engine lights
are on. the sparkplugs, wires, dist, cap, and rotor, coil , ecm it
has been changed but it is still doing the same thing. i keep
getting code 35 & 41 . I would really appreciate any info. Thanks.
Old Feb 5, 2009 | 12:56 PM
Crazy4x4RT's Avatar
Crazy4x4RT
It may be a wire problem. Try reposting in the 1st gen dakota forum. This will give you much more responses.
