95 dakota ac/heat controls not working
The heat/ac controls on my 95 3.9L do not work. I pulled out the control module, all vacuum hoses are connected. I pulled the dash apart, pulled out the evaporator case and found that the black hose is disconnected (yellow, red, light green,dark green are connected to the proper actuator). This black hose should be connecting the controls to the engine vacuum system. I can't find anywhere that this hose is supposed to connect to, can someone point me in the right direction?
- Dan M
- Dan M
figured it out, black hose plugs in behind air intake, hard to find cause the hose it connects to is very small (not long) and hard to see.
- Dan M
- Dan M
