computer troubles
<FONT color=black face="Arial, Helvetica, sans-serif">i have a '90 dakota with the 3.9 L V6. i have just put on the following: K&N stock size air filter, new conrad rotor and cap, bosch double silicone wires, bosch platinum plugs, and a new throttle position sensor. i had had troubles before with gas milage and decided to do a tune up and performance got no better, so i decided maybe the computer needed reset. i disconnected the battery for a half hour and now the thing sounds like crap. does anyone know of any little important steps i need to know of for reseting one of these things. also, i has a tbi injection system that is running very rich and i don't know why. thanx for any help.</FONT>
thanx guys. it's been about 500miles and it's doing fine. although i have a little problem with the oxygen sensor....uh it can't exactly function correctly because i replaced the muffler with a glasspack after the catalytic converter shot it's guts into the muffler, and i didn't have the 185 bucks for a new cat....so it's just a glasspack exhaust. call me bad
yeah same here!!
go to this site here, he hase a chip that will trick the PCM into thinking you have a properly functioning cat and o2...so you can keep your cat less set up!!!!
www.thefastman.com
www.thefastman.com
