Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Rough Idle
Old Dec 20, 2012 | 01:50 AM
hamilton88's Avatar
hamilton88
Default Rough Idle
When I bought this truck it had a rough idle so I replaced the IAC. The big problem with this is mainly when I am driving down the road the truck seems to clog up and not get enough fuel and spudders. I have to throw it in neutral and rev it high and then put it in drive in order to get it going again. I ran some fuel injector cleaner through it and it quit doing that for a good month. Yesterday it started up again and I'm not sure what is causing it to act this way. I also looked into o2 sensor relay fuses but couldn't find any. And suggestions?
Old Dec 20, 2012 | 03:27 AM
dino30's Avatar
dino30
check for a clogged fuel filter or a vacuum leak .. Both can cause what you are describing.
Old Dec 20, 2012 | 11:25 AM
Crazy4x4RT's Avatar
Crazy4x4RT
What year is your truck so I can move this into the correct section?
Old Jan 8, 2013 | 02:25 AM
bluebeastr/t's Avatar
bluebeastr/t
Ive seen that when you start the truck after 30mins after running for awhile
