Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
I hate drum brakes!!@!
Old Dec 23, 2013 | 09:40 PM
mikez104's Avatar
mikez104
Originally Posted by LorenaHornbeck
quite support discussion it has been yet to me to go though as i have faced the same trouble in past and had to juggle a lot to make it right as i was out of mind to go good with it .. but now has got some facts regarding the fix to the wear
Glad to hear that all this may have helped someone! Figured I'd post the install video also.
Old Feb 14, 2014 | 06:41 PM
mikez104's Avatar
mikez104
Drum brakes strike again! Or maybe it's just the Dakota brakes in general. So I hear a noise in the left rear brake and remove the drum to find that the self adjuster was all out of place. Yeesh. I decide that since it is jacked up and the wheels are off, I will bleed the back brakes because it seems that they just don't grab until the very bottom of the pedal. That's where the fun begins.
Can't get the bleeder open because it is so rusted and disintegrated that it is now permanently part of the wheel cylinder. So I get new wheel cylinders. Of course the brake line crumples when I try to take it off. So Back to the store for brake lines. I then notice the connection on the top part of the rubber line is rotted and looks like it going to blow. Back to the parts store...
After replacing all that mess, I bleed the brakes and the back brakes still don't start to catch until the pedal is near the floor. Where do I go from here? Master cylinder?
Old Feb 18, 2014 | 07:00 PM
Brian in Tucson's Avatar
Brian in Tucson
Adjust the brake shoes until they just start to bind up the drum. Then back them off just enough so that they don't bind.
Brakes are kinda important, I'm not sure that I would helicoil the caliper bracket--you could take it off and have a machine shop MIG in some metal and then have it drilled & tapped. But if you helicoil and it fails, it does get exciting at 75 mph.
After a lifetime of having cars that I work on, I'm a believer in replacing wheel cylinders when I do the shoes. Wheel cylinders are so cheap as to be a non factor. & having one leak destroys your nice new brake linings.
I don't hate brake drums, I hate corrosion. One of the nice things about living in the desert SW is that we don't seem to have much problem with that. I grew up in SW Michigan, and remember bumpers falling off from rust. & broken lug studs (every year!) & fasteners that look like they've been welded on and the soaked in salt brine.
Old Feb 19, 2014 | 11:41 PM
mikez104's Avatar
mikez104
Well, I got them to a state that I'm happy? with. last weekend I adjusted them up til they were rubbing just a little then wrapped the bleeders in Teflon tape and bled the **** out of them with the vacuum bleeder. They are a lot better but there is still some travel before they catch.
I agree on the wheel cylinders. I got a set of Raybestos for like $9 a piece on amazon with free shipping. I feel better that I replaced all the rear brake lines also and now have good clean fluid coming out of the lines.
And yes, being a western PA vehicle it looks as though the under carriage has been in the ocean for 20 years. This winter has also been brutal. I bought the truck so I would not have to have my charger in the salt this winter. It ends up that that Dakota spent more time my garage that the charger did.
