Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Identify motor type and size
Old Dec 18, 2015 | 12:01 PM
Jagil's Avatar
Jagil
Lightbulb Identify motor type and size
I purchased a 2000 Dodge Dakota used motor was suppose to be changed so now got problems nobody seems to know what size motor is all i know is it is a V-8 magnum but am having problems with codes identifing locations of them on motor i need to know what size motor it is 4. or 5.
have numbers from block but cant find out anything. all pics i seen on here diff.please any suggestions???
Old Dec 18, 2015 | 10:03 PM
What?
Old Dec 19, 2015 | 01:52 AM
RalphP's Avatar
RalphP
Well, to determine if it's a 5.2/5.9 or a 4.7, does it have overhead cams or not?
If it does, and it came from a Dakota, it's a 4.7 .
The best way to determine if it's a 5.2 or 5.9 from outside is to check the counterweighting on the flywheel / flexplate. Of course, technically the method at http://www.magnumswap.com/dodge-magnum-engine-search/ should also work fine, and may be easier than determining if the flexplate or flywheel is neutral balanced or not.
RwP
