Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
96 Dakota Crank No Start
Old Aug 4, 2019 | 05:39 PM
John Hagel's Avatar
John Hagel
Default 96 Dakota Crank No Start
OK at my wits end on this truck
3.9l 1996 Dakota
Was intermittently stalling now will crank but no start
Here is the list of I did
Replaced:
IAC, Crank Sensor, Cam Sensor, Coil, Rotor, Battery, PCM, all relays
Checked: Voltage to Fuel Pump Good, Removed Fuel line at fuel rail and gas is pumping
No voltage to coil, checked with spark tester and tested at connector with multi meter- No voltage
Checked infamous splice under the relay box... it was good
Check codes with OBDII- No codes
Only thing I can think of that's left is... I got a bad out of the box part (but would think I would get a code)
Possibly a timing chain
For the sake of all that is good and Holy, please help my impending mental breakdown
