Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
2001 Dakota - Speedometer
Old Aug 24, 2006 | 05:34 PM
Neils Truck's Avatar
Neils Truck
Default 2001 Dakota - Speedometer
HI....first posting in this forum.
Have a 2001 Dakota and the speedometer is pegged at 160 MPH! While this forum has several postings with speedometers that don't work at all or dont work below 20 MPH, none refer to a problem where the needle is pegged all the way up. Noticed this after cleaning the battery terminals / cables (disconnected them) if that has any bearing on it. Given that this is an electronic component, suspect that its a sensor, but which one? No other lights are affected.
Was hoping that someone has seen this before. Thanks
Old Aug 30, 2006 | 12:24 AM
black_bird's Avatar
black_bird
Default RE: 2001 Dakota - Speedometer
easy led foot.... [8D] haha my names neil too and i drive an '01 Dakota. Ive had this problem too after disconnecting the battery. Just drive the truck for awhile it will eventually go back to normal. Mine did. Good luck..
-Neil
Old Aug 30, 2006 | 01:02 AM
dodgerules86's Avatar
dodgerules86
From the 2001 Service Manual:
The instrument cluster actuator test will put the instrument cluster into its self-diagnostic mode. In this mode the instrument cluster can perform a selfdiagnostic test that will confirm that the instrument cluster circuitry, the gauges, and the PCI data bus message-controlled indicators are capable of operating as designed. During the actuator test the instrument cluster circuitry will position each of the gauge needles at various calibration points, illuminate each of the segments in the Vacuum-Fluorescent Displays (VFDs), and turn all of the PCI data bus messagecontrolled indicators on and off again.
Successful completion of the actuator test will confirm that the instrument cluster is operational. How- ever, there may still be a problem with the PCI data bus, the Powertrain Control Module (PCM), the Engine Control Module (ECM), the Central Timer Module (CTM), the Transmission Control Module (TCM), the Transfer Case Control Module (TCCM), the Airbag Control Module (ACM), the Controller Anti-lock Brake (CAB), or the inputs to one of these electronic control modules. Use a DRBIIIt scan tool to diagnose these components. Refer to the appropriate diagnostic information.
(1) Begin the test with the ignition switch in the Off position.
(2) Depress the odometer/trip odometer switch button.
(3) While still holding the odometer/trip odometer switch button depressed, turn the ignition switch to the On position, but do not start the engine.
(4) Keep the odometer/trip odometer switch button depressed for about ten seconds, until CHEC appears in the odometer display, then release the odometer/trip odometer switch button.
(5) A series of three-digit numeric failure messages may appear in the odometer display, depending upon the failure mode. If a failure message appears, [write them down and post them back]. If no failure message appears, the actuator test will proceed as described in Step 6.
(6) The instrument cluster will begin the Vacuum Fluorescent Display (VFD) walking segment test. This test will require the operator to visually inspect each VFD segment as it is displayed to determine a pass or fail condition. First, all of the segments will be illuminated at once; then, each individual segment of the VFD will be illuminated in sequence. If any segment in the display fails to illuminate, repeat the test to confirm the failure. If the failure is confirmed, replace the faulty instrument cluster. Following completion of the VFD walking segment test, the actuator test will proceed as described in Step 7.
(7) The instrument cluster will perform a bulb check of each indicator that the instrument cluster circuitry controls. Each of the instrument cluster circuitry controlled indicators except the cruise indicator and the overdrive-off indicator are illuminated by a Light Emitting Diode (LED). If an LED fails to illuminate during this test, the instrument cluster must be replaced. Following the bulb check test, the actuator test will proceed as described in Step 8.
(8) The instrument cluster will perform a gauge actuator test. In this test the instrument cluster circuitry positions each of the gauge needles at three different calibration points, then returns the gauge needles to their relaxed positions. If an individual gauge does not respond properly, or does not respond at all during the gauge actuator test, the instrument cluster should be removed. However, check that the gauge terminal pins are properly inserted through the spring-clip terminal pin receptacles on the instrument cluster electronic circuit board before considering instrument cluster replacement. If the gauge terminal connections are OK, replace the faulty instrument cluster.
(9) The actuator test is now completed. The instrument cluster will automatically exit the self-diagnostic mode and return to normal operation at the completion of the test, if the ignition switch is turned to the Off position during the test, or if a vehicle speed message indicating that the vehicle is moving is received from the PCM on the PCI data bus during the test.
(10) Go back to Step 1 to repeat the test, if required.
