Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
1988 Dakota 4wd 3.9 litre w
Old Dec 13, 2003 | 02:59 AM
Murray's Avatar
Murray
Default 1988 Dakota 4wd 3.9 litre w
<FONT face="Arial, Helvetica, sans-serif" color=black size=3><IMG src=smileys/smiley6.gif border="0">I have a 88 Dakota 4X4 3.9 litre. It is a great little truck but it started acting up</FONT></P>
<FONT face=Arial size=3>and just stopped. It stops after idling for long period of time when you put it into </FONT></P>
<FONT face=Arial size=3>gear and will not restart for a period of time. There seems to be pressure to the</FONT></P>
<FONT face=Arial size=3>TBI so pump is running. Also have spark. Anybody have any ideas?? Or have </FONT></P>
<FONT face=Arial size=3>same?? </FONT></P>
Old Dec 13, 2003 | 04:05 AM
5.9rm's Avatar
5.9rm
obviously there is either not enough fuel or air getting to the cylinders. a lack of engine vacume (causing the cylinders to not get enough fuel/air mixture)could be one reason, you fuel injectors could be bad, it really could be anything that has to do with either fuel or air getting into the cylinders.</P>
aaron</P>
Old Dec 28, 2003 | 01:50 PM
Dakota1124's Avatar
Dakota1124
Check how much fuel pressure it has. As with all fuel injection it must have a minimum constant pressure or it will not start and or stay running. Also replace the fuel filter.
Old Jan 15, 2004 | 08:21 PM
90dakota's Avatar
90dakota
I'd try replacing the fuel filter it's an easy job you can do yourself
and it should be done every once in a while anyway even if it's not
causing your problem
