Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Damn A/C compressor ;(
Old Nov 24, 2006 | 03:13 PM
V8Boss's Avatar
V8Boss
Default Damn A/C compressor ;(
Hi all. I know with most cars the A/C Compressor only runs when the A/C is on or when you run the defrost. With my Dakota, the compressor runs no matter what air setting I have it on ie: cold, hot, out of the dash, on the feet, defrost. Usually I wouldn't mind if I was driving a 4 banger that gets great gas mileage, but unfortunately I got the 4.7 that, as we all know, sucks on gas mileage regardless if you have the compressor running or not. Is there anything I can do to get that to stop running all the time when I have the air on? Thanks!
Old Nov 24, 2006 | 05:52 PM
dodgerules86's Avatar
dodgerules86
Default RE: Damn A/C compressor ;(
You could: a) remove the A/C compressor clutch relay (located in a black box in the engine compartment) or b) unplug the electrical connector for the compressor (located kinda near the compressor).
Don't know what would cause the compressor to run in a non-AC selected, non-defrost vent setting, but, do one of the above, and that compressor won't run.
Old Nov 24, 2006 | 06:24 PM
V8Boss's Avatar
V8Boss
So would that be bad to do...like it wouldnt have any negative effects right?
Old Nov 24, 2006 | 06:58 PM
dodgerules86
Won't have any bad side effects.
Of course, you will want to keep a reminder for yourself that you disconnected it, so next summer, you don't forget and think its broke.
Old Nov 24, 2006 | 11:57 PM
V8Boss's Avatar
V8Boss
Thanks for the info, Dodge! I'll probably pull out the relay so no crap gets into the connector.
Old Nov 26, 2006 | 10:20 AM
V8Boss's Avatar
V8Boss
Well, I pulled the relay, but the engine still kicks up about 200-300 RPMs when I turn the air on. I guess I will try pulling the connector too and see if that works at all.
