Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
removed negative cable.now wont start
Old Feb 11, 2007 | 11:07 PM
barstickbilly's Avatar
barstickbilly
Default removed negative cable.now wont start
removed negative cable on 98 dakota to change oil pump, now lights flash and motor wont start when i rehooked battery, HELP
Old Feb 13, 2007 | 11:45 AM
red9535's Avatar
red9535
Default RE: removed negative cable.now wont start
Does it crank? Or do you hear nothing when you turn the key
Clean your battery terminals. Then charge your battery for a couple hours, then try again. Its possible it got drained somehow, and now doesnt have enough cranking amps. The reason i suggest this is because my sisters beetle will crank just a liiiiittttleee bit, and all her lights will flash and go crazy but it wont start when her battery is dying/dead.
