Dodge Dakota The tough, mid size pickup, the Dodge Dakota. The Dodge Dakota has everything the big boys do with a mid size truck price.
Fan clutch or water pump replacement
Old Aug 23, 2004 | 09:24 AM
mjbmet's Avatar
mjbmet
Default Fan clutch or water pump replacement
On my '98 3.9L v6 Dak, I have a water leak from between the engine and the back side of the radiator fan (behind the pulley) and the entire assembly (fan blades and pulley) is loose and can be moved about 1/2 an inch front to back. Since there is the water leak, would this indicate a replacement of the water pump or am I looking in the wrong direction?
Thanks,
Mike
Old Oct 14, 2004 | 04:33 AM
madsn11's Avatar
madsn11
Default RE: Fan clutch or water pump replacement
I just had the same problem. i was leaking antifreeze like crazy and it turned out to bo the bearings in my water pump had gone out from right behing the pulley. doesn't take too much to replace about 70 bucks and and hour or two.
