Help!! Malfunction indicator light (MIT) problem!
I have a few problems with my car (2013 Dodge Dart Limited) and will be taking it back to the dealership to have it looked it this Thursday (under warranty). I was wondering if anyone knows a temporary problem fix or anything of that sorts because I need to drive my car to and back from work and am hesitant in using it due to what occurred today.
1- my MIT lighted up as I was driving back home from work. What happened was the light lit up and the accelerator had a tough time going (had to press extra hard just for the car to accelerate) and the gear (where it says P, D, R and N) lit up all red instead of the usual white. Once I turned off my car and turned it back on, these problems went away but the MIT light is still on. Anybody know what the possible fix it is?
2- every time I put my car into Reverse and drive in reverse, I shift the gear to Drive and it makes his sudden movement as the car moved forwards and backwards suddenly and strongly. This I believe has to be checked out by the dealer but what seems to be the problem here?
I have pictures if needed. Please message me with an email or cell phone number so I can send it to you. This is my first car and I'm already having a bunch of trouble with it. I bought it certified used so it shouldn't have so many problems with it...thank you in advance!!!!
