Dodge Dart The Dodge Dart forum is the place for all Dart 2013+ Owners Discussion
1.4 misfire
Old Nov 2, 2025 | 04:12 PM
needatfb's Avatar
needatfb
Default 1.4 misfire
Hello all, Trying to help a friend with there 2013 1.4 dart. Stated it was running rough with oil on spark plugs. They took it to a shop and said cylinder 1 had low compression. I replaced the valve cover gasket and spark plug tube seals for the oil on the spark plugs. Starts up and runs rough. The codes im getting are p2096, p1d73,p0137, p0301,p0300, Not sure what codes they had before as my little scanner seems to not clear them. I swapped coil packs and spark plugs to see if the problem swapped but it did not. Even with just starting it a couple times #1 spark plug had oil on it already. I think its something internal like rings and its a bit beyond my scope of work. Just wanted to post on here incase its something im overlooking .
Thank You
Old Jan 17, 2026 | 03:23 PM
mandmvanmetre's Avatar
mandmvanmetre
I had a similar issue, head gasket ETC. Replaced my coil packs and they were not OEM. Misfire issue almost immediately. Mechanic replaced with OEM coil packs and it solved the issue. More expensive I guess, but it worked.
MV
