Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
'92 Daytona overheating
Old May 30, 2007 | 06:12 PM
Jaxxine's Avatar
Jaxxine
Default '92 Daytona overheating
Hey, it's been awhile since I was last here, but I had good luck last time...my 1992 daytona 2.5 litre is (auto) has been overheating lately. I drive on the highway alot so this is when I am noticing it.
I was wondering how do I tell if its just the thermostat screwing up or if I have to replace my headgasket?
Does the headgasket also influence oil pressure? The oil pressure drops a bit, but I think thats due to alot of highway driving. Could anything else be causing my car to overheat? I 've had the rad flushed and checked for pressure leaks and its good, so now I'm unsure where to start. Any ideas? I've got 230 k on it now.
Thanks,
Jaxxine
Old Jun 1, 2007 | 06:03 PM
outsider75's Avatar
outsider75
Default RE: '92 Daytona overheating
use a good flush to flush out the radiator for starters
then install a 180 thermostat with a fresh gasket
check all the hoses to make sure none are soft or might have a pin hole
and also check the fan motor as they sometimes go out or turn slower as they get older.
Old Jun 9, 2007 | 09:47 PM
kct's Avatar
kct
To help you figure out if there is a headgasket leak. Check the coolant reservoir for bubbling/burping while the engine is running. Also periodically check the coolant level in the radiator. Check the oil cap and the radiator cap for a light brown milky sludge. On enginestartup see if you've gotwhite smoke from the tailpipe.If there is a 'yes' to one of the above, you'll need a new headgasket.
