Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
Loose Shifter
Old Aug 22, 2007 | 06:23 PM
JustinZero's Avatar
JustinZero
Default Loose Shifter
Hey all!
I have a big problem.
I have an 85 daytona with a tranny from an 87 ( four speed turbo) The shifter just went loose one day. It does not shift into gear, though I can feel the clutch grabbing. The shifter just moves around all over the place and the car feels like its stuck in first gear.
Some one mentioned to me that there might be a loose connection to the Tranny but I cant find any descriptions or diagrams about what I am looking for and how to get to it....does the shifter hook into the tranny from the bottom or from the top?
I am new to the Daytona family so all help is extremely appriciated.
Thanks!
Old Aug 22, 2007 | 08:02 PM
damageincracing's Avatar
damageincracing
Default RE: Loose Shifter
Had this same problem on my 85. Pop the hood and look down at the back of the tranny (between trans and firewall) below the brake booster. That's where all the "shifting" happens. There are two cables (that run inside to the shifter) with ends that just "pop" onto the ball studs on the linkages. Mopar actually had a fix for this (a couple of clips that went over the ball studs and caps) and I haven't had a problem since. When one pops off you can take the shifter inside and just run it in circles. Get hold of your local dodge dealer for the clips, since I think the recall/TSB is a little out of date on this (can't hurt to check though). Might be able to get it fixed for free if that's the problem.
Old Aug 22, 2007 | 10:15 PM
JustinZero's Avatar
JustinZero
Ok...I'll check that out...thanks!
Old Sep 25, 2007 | 08:59 AM
OFG's Avatar
OFG
I had the same problem with my 1990 5 speed, and it looks like the grommet (bushing?) at the shift lever just deteriorated from old age.
I had driven for 5 or 6 miles, and downshifted for a stop sign.
When I went to start up, the shifter flopped loose and would not
change gears.
I was in third, and was able to burn the clutch to get home.
I took it apart, and saw the loop for the shifter cable laying on the
floor below the shifter lever and small pieces of the bushing laying
around.
Called the dealer, and they will sell only the entire cable assy
($130.00). NFW.
I fabbed a 5/8 OD bushing, 1/2" wide and drilled a hole to get the
car movable.
Does the group have any ideas where to get a good replacement? Does
Spiva make anything like that,or just suspension bushings?
I also need a black drivers seat belt and console for this same Daytona. Where is a good place to look for that type of thing on-line? The local junk yards have crushed everything.
Thanks in advance -
OFG
Old Sep 26, 2007 | 08:39 PM
OFG's Avatar
OFG
After some suggestions from the Yahoo LeBaron forum, I have purchased a set of 4 red (!) bushings from Boogers Bushings (yes, that is the name) for $22.00 delivered.
They should arrive next week sometime and I will post my experiences after I get them installed.
OFG
Old Oct 1, 2007 | 07:13 PM
OFG's Avatar
OFG
The Booger Bushings are in and highly recommended.
They arrived in a few days (to Ohio from Wisconsin) - $22.00 delivered.
He even sent me a spare at no extra charge since there were two sizes that year.
Got them installed according to the instructions - Booger was absolutely right, getting the console off and getting to the bushings was a lot of trouble compared to changing the bushings themselves.
The shifting feels great, and I only changed at the shifter (bushings at the tranny are still original).
If you want to get a set, go to ebay, search for booger bushings and check 'search title and description".
Or if anyone wants, I will be glad to answer any questions.
OFG
