Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
can someone help car quit?
Old May 3, 2005 | 04:02 AM
little turbo's Avatar
little turbo
Default can someone help car quit?
my 1990 daytona started acting up a few months ago and it quit today dead no life no spark?
here are the symtoms the car used to run fine than quit i changed the dist pickup and it was all well .than about a month ago it started to quit on the odd occasion than started to do it more often. when it quits the asd relay buzzes like crazy and fires the injectors and the speedo jumps in unison to the relay dance.i cant seem to pull any codes from the on off on off on code sequence no check engine light?
here is what i have done to try to solve this problem
new dist pickup
new fuel pump,filtre
new coil
what in the h is happening here pleeeeze hellllpp!!!!!
Old May 3, 2005 | 05:52 AM
GTCandGTSturbo's Avatar
GTCandGTSturbo
Default RE: can someone help car quit?
Did you use a Mopar dist pickup (HEP)? If not, that could be it.
If you have a SMEC, swap it out to check that.
Old May 6, 2005 | 01:51 AM
blueturboII's Avatar
blueturboII
Make sure u have a good clean tight body ground connection just behind and below your battery.
