Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
hid lights flickering
Old Apr 12, 2010 | 12:00 PM
fatboy3d's Avatar
fatboy3d
Default hid lights flickering
can someone help me fix my lights
Old Apr 23, 2010 | 06:47 AM
skatedonttrip's Avatar
skatedonttrip
Default flickering eh?
if you tap on the dash by your headlight switches and it effects your lights it's pry the switch or just the connection at the harness. if knocking on there has no effect try tapping on the bulb / housing. if that does anything u may just need new bulbs or tinker with the leads on the bulb clips. . . i was having connection issues in my dash right beside the spedometer where the harness for the headlights n blinkers connects. i squirt some bulb jelly in there to prevent corosion and keep a good connection and it dd the trick. i also tweeked the little pins in the wire harness so they would connect better. hope that helps. . . you can also follow the wires from the bulbs to check the ground wire. also see if your fuse might be loose. if all else fails u can run your own wires and a switch (cheap fix)
