Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
My car stalls for some reason PLEASE HELP
Old May 25, 2005 | 02:10 AM
88 Dodge Daytona's Avatar
88 Dodge Daytona
Default My car stalls for some reason PLEASE HELP
hey
I own a 1988 Dodge Daytona. For the past month it has been stalling. It does not matter how fast or slow, Accecel or slowing, turning, revsersing. It will just die. I have replaced the Veh. Speed Dist. Sensor., fuel filter. it doesnt matter is it is hot or cold. just today i repleaced the hall effect. i have yet to drive it. however when i started up my d.d. after i installed the new hall effect it idled really wierd. i have also replaced the timing tenioner and belt. please help, i really need it. every car shop i have called they just tell me that i should just junk the car. i really want to save this car so please help. \
Not to forget i also get error code 23. UM.......... or ya plus it has yet to stall while reversing or turing so ya i kinda over said things. please help
Old May 25, 2005 | 02:25 AM
88 Dodge Daytona
Default RE: My car stalls for some reason PLEASE HELP
also my mileage dosent work HHHHHHEEELLLLPPPPPPPPP
Old May 25, 2005 | 01:45 PM
CSXT802's Avatar
CSXT802
the trouble code 23 is for the air charge temp sensor. as far as the stalling goes ,I would look into the coolant temp sensor and the oxygen sensor.
Old May 26, 2005 | 01:43 AM
88 Dodge Daytona
good news, when i drove my DD to work and back home, it did not stall. On my way home i stopped at are local and only gas station aand filled my tank up. started my car back up and drove it the rest of the way home. It did not stall. but hte next time i will be driving it will be on friday so i will see how it goes.
Thank YOu to the person who replied. Well about that reply i have already bought a air charge temp sensor however i could not replace it becuase i could not find the correct spot it in. i unsrewed some that look exatly like the one i bought but when i took out the old one it look differnt beceuase instead of it being kinda of opened at the end that goes into the throttle body it was a rod and had white things all around the tip so i did not replace it. i do not think it is the O2 sensor because i would still be stalling but thank you for any and all replys
Old May 26, 2005 | 04:36 AM
71RoadRunner's Avatar
71RoadRunner
Hopefully the hall effects was the problem. You still need to change the charge temp. sensor though, it won't keep it from running, but it will cause it to run a little off. The '88 Shelby Z I had is currently throwing the same code and it runs and drives, but it's down on power big time and barely barks the tires when launched hard when it should, and use to, boil the tires into towering pillars of smoke. It is also throwing the code 45 which is for overboost, but I believe it is a result of the other codes problem causing this problem. My '88 Shelby Z had and to this day still has a problem with the speedometer and odometer, they work off and on when they want to. They both run from the same thing so I'm guessing that your speedometer doesn't work either.
Old May 27, 2005 | 12:10 AM
88 Dodge Daytona
I would of liked to have changed the air charge temp sensor. Only if i Knew where it goes. I looked all around the throttle body but cant find it. It is definatly running a little off. When I started it up today it idle at about 1500 then started to drop and stoped at 1000 then it would go alittle up then a little down up down, fast down fast up, you get the point. i just changed me vhec. dist. sensor. b/c i was getting the code 15. Before i replace it, my speedom. would go on and off. but now it stays on all the time. however for my odometer, it dosen't work.
I hope that when i drive my car to work tommorw it wont die.
Old May 27, 2005 | 03:07 PM
t2turbo600's Avatar
t2turbo600
air temp is on the intake mainfold in middle should be plastic
Old May 27, 2005 | 05:36 PM
88 Dodge Daytona
well when i bought it before i found somthing that looked extaly like it. the connector and everything on it was eacxtly the same but when i unsrewed it the sensor had a white paste all around the tip. also the tip was a bar and he one that auto zone gave me had a "basket" looking tip with like a "ball" in side.
Old May 28, 2005 | 02:30 AM
88 Dodge Daytona
well i just got home from work and my car did NOT stall. Plus it was raining out and it was cold, about 45-50 degrees. So tommorrow will be another test with driving it to work. for the past couple of weeks since it has been stall, i just have been driveing it everyother day.
Old May 28, 2005 | 06:35 AM
71RoadRunner
Well it's looking more and more like you got it fixed with the hall effects.[sm=smiley20.gif]
