Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
How to remove trans 1991 Daytona
Old Jul 27, 2005 | 03:31 PM
tinkerreknit's Avatar
tinkerreknit
Default How to remove trans 1991 Daytona
How can I find out how to remove the transmission? It doesn't seem self-explanatory!
Old Aug 10, 2005 | 03:13 AM
pithyus's Avatar
pithyus
Default RE: How to remove trans 1991 Daytona
I’m also having Transmission problems. I own a 91 Daytona 5 speed. I had trouble keeping the car in 5th gear; when I was driving it would just pop out of gear.
Now it sounds like something is bouncing around in the transmission and the car jerks, so I parked it.
I have never had to do any major repairs on this car, so I need a little advice. Naturally I expected to have to remove the transmission, but when I got under the car to do the job I found that I am too inexperienced.
It appears that I need to remove the axles first. Is this right? If so, how do I go about this?
Can anyone offer me any advice?
Any help would be greatly appreciated.
Old Aug 15, 2005 | 04:55 PM
heptagle's Avatar
heptagle
i have been told that it is extremly hard to put in a transmission in a daytona. I was also told that if the tranny im my 1991 daytona ever went out to go to a mechanic and let them do it since it sucks real bad, especially on a daytona.
just my 2 cents
Old Aug 17, 2005 | 02:04 AM
87Indy500's Avatar
87Indy500
It's not that hard. Pull the axle's, support the motor/trans from the top if possible so that you can raise and lower it and remove the motor mounts, front, rear and tran's mount and then start on the bell housing. You'll spend most of the time removing the air box and other stuff that will get in the way. It also nice to have help while doing it because the tranny's are heavy and more than likely once you get it away from the block you find that it will sit nicely on your chest until you roll out from under the car.
A factory service manual will go a long way if you have access to one. Try you local Dodge/Chrysler dealer to see if they will loan on out to you if you can't find one.
Old Aug 17, 2005 | 06:51 PM
tinkerreknit
Thanks guys! In progress now.
Old Aug 17, 2005 | 11:44 PM
pithyus's Avatar
pithyus
Thanks 87Indy500.
I am having a hard time finding a manual. I Think the only way I am going to get one is if I buy it online.
