Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
balancing shaft question
Old Nov 12, 2005 | 02:50 PM
z_green2005's Avatar
z_green2005
Default balancing shaft question
I have a 91 daytona w/ 2.5L turbo. I am removing the balancing shaft assembly...but next to the water pump by one of the bolt holes, there is a small hole... what is this? and do i need to worry about it??
Thanks
Old Nov 22, 2005 | 06:44 AM
87Indy500's Avatar
87Indy500
Default RE: balancing shaft question
If the hole you're talking about it right next to the main bearing cap on the block web, YES you need to worry about it. It supplied the balance shaft assy with oil and it will need to be closed off since it goes directly into the main oil galley. If you do not block it off, you will have ZERO oil pressure and damage the engine....
See details HERE
