Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
turbo1 burning anti-freeze out exhaust
Old Mar 18, 2006 | 01:23 PM
pacifica88's Avatar
pacifica88
Default turbo1 burning anti-freeze out exhaust
I have a 88 pacifica 2.2l turboI has white smoke out the tail pipe and behind the motor. checking to see what my options are for performance upgrades. and what would i need to add a intercooler????
Old Mar 20, 2006 | 12:44 AM
stockyard's Avatar
stockyard
Default RE: turbo1 burning anti-freeze out exhaust
Not sure about the performance upgrades for that car, but the white smoke is almost a sure sign of either a cracked head or block, or a blown head gasket. As far as the smoke from behind the motor, that could be from the exhaust manifold gasket having holes in it, which could be letting that smoke out of the exhaust ports on the back of the head (that is, if the manifold is on the back and not the front), or that could also be due to a blown head gasket. Smell the white smoke (don't put your face up to the pipe or anything). If it has a sweet smell to it, then your car is burning antifreeze. When the head gets cracked, it lets antifreeze into the combustion chamber, which is what causes the white smoke.
Old Mar 25, 2006 | 06:18 PM
pacifica88's Avatar
pacifica88
i know this sounds like a head gasket or a cracked head but there is no mixture of fluids and the car still ran perfect when it was parked about 11 months ago. just needed a starter and didn't have time to worry about everything at that time.
Old Mar 27, 2006 | 04:14 PM
shnormo's Avatar
shnormo
You don't have time to worry about what is mechanically wrong, but you are worried about the performance aspect? Blown headgasket+antifreeze in combustion chamber+blowby = Siezed up crank!!!
Old Mar 28, 2006 | 09:37 AM
damageincracing's Avatar
damageincracing
When the head gasket went on the first engine in mine there was no mixing of fluids either. It was dumping antifreeze directly into the cylinder. It did the same thing on engine #2. No milky oil, no foam in the coolant, just a ton of white smoke. It's your head gasket.
Old Mar 28, 2006 | 02:58 PM
pacifica88's Avatar
pacifica88
for one i didn't say i don't have time for it now ,i didn't at the time. that is why i am asking for some info now.... but thanks anyways Norm .. for what i'm not too sure...
Old Mar 28, 2006 | 03:02 PM
pacifica88's Avatar
pacifica88
Thanks for the info DAMAGE I do appreciate the help. I was also wondering how much improvement a inter-cooler would make and if it would be worth the hassle for this motor???
I would like to put some time in this car but i want to do everything all at once motor wise...
thnx Rick
Old Mar 29, 2006 | 09:42 AM
damageincracing
Anytime you can cool an incoming charge, wether it's air or fuel (or both), it's gonna give you a gain of something. Just not sure how much. The perfect setup would be to have cold air, cold fuel, hot engine. Cold, dense air holds more fuel in a vapor state, cold fuel attomizes better out of an injecter, and the hot engine burns fuel better. Flashback from auto school... LOL!
