Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
92 Daytona Water Pump
Old Jul 9, 2006 | 07:36 PM
waffles007's Avatar
waffles007
Default 92 Daytona Water Pump
Hey all,
I have a 92 Daytona and i recently replaced the water pump because it was leaking out of the bleeder hole when it's blown. After replacing the water pump, gaskets and o-ring and left it to sit for a day, then i started to refill the antifreeze.... the antifreeze was still leaking out of the hole... what is going on i'm stumped. I removed the water pump and checked the gaskets thay are fine. Any ideas about what might the problem be?
Thanks,
Devin
Old Jul 10, 2006 | 01:41 AM
damageincracing's Avatar
damageincracing
Default RE: 92 Daytona Water Pump
What engine do you have, the 2.5? Is it a new waterpump, or a reman or junkyard pump?
Old Jul 10, 2006 | 08:46 PM
mrrccc's Avatar
mrrccc
if ur still having problems, you can try teflon(sp) tape. good for closin gaps. btw i think he has a 3.0, most people would specify if it was an iroc or r/t which of course would have the 2.5. well most of them anyway
Old Jul 10, 2006 | 11:31 PM
waffles007's Avatar
waffles007
Hey,
yes it is a 3.0 and i don't believe this hole is supposed to be plugged, all the manuals i have found don't really say to much about this and there was no plug in the water kit i received. BTW this is a new water pump not remanufactured.
I could use all the help i can get cause i'm at my wits end here, thx
Devin
Old Jul 21, 2006 | 12:27 AM
bigc17055's Avatar
bigc17055
Well devin i have a 1990 3.0 and i think that they are the same engine and it was not fun getting to the water pump. If it is the same engine there are two o rings that make its way to water pump. They are on the water inlet pipe that comes from the right side and makes its way to the left side if the engine to the waterpump.
