Wiper problem
Hello, My wipers will not shut off its an intermitent problem I dont know if its the body control module or what but when they do shut off and I have to use them they only work on two speeds not the other ones! any help? oh and the head lights once in a rare while go down, not offten though and sometimes its on one that goes down.[sm=boohoo.gif]
Change the wiper switch or take off the the one you have and blow on and clean the contacts. Sometimes the vibration from the car will loosen the switches on the "pod". The "pod" tends to get misaligned if one of the fasteners gets broken and it can drop. And the intermittant thing with your headlamps is an indication that the module is going, but check the relay first by taking it out and cleaning the contacts on that too. Hope this helps. [sm=signs003.gif]
