Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
92 v6 running rough on idle
Old Jul 23, 2006 | 04:46 PM
OmegaESIROC's Avatar
OmegaESIROC
Default 92 v6 running rough on idle
Ok so last night I was Driving home no problems when my check engine light popped up. At the same time during stopped or idle times the engine ran rough shakeing quite a bit on a sort of steady pulse.
I did note a different scent to the exhaust was sort of a sweet gas smell.
this morning i ran the key code test and came up with 4 codes.
12 - dont know this one
37 - torque converter clutch solenoid CTK
27 - Injector Control Circuit
41 - Generator field not switching properly
Any help would be Much appreciated as my income is very limited atm.
Thanks
Old Jul 28, 2006 | 12:12 AM
87Daytona's Avatar
87Daytona
Default RE: 92 v6 running rough on idle
Could possibly be running rich, and for the torque converter and the generator, beats the hell outta of me... [>:]
Old Jul 28, 2006 | 01:54 AM
OmegaESIROC
yea there is a good chance those are old codes. anyway I have taken the car in for repairs so hopefully they can diagnose it better. fortunatly i wont have to pay for anything!
THANK YOU AUNTIE!!!
Old Aug 5, 2006 | 12:17 AM
grytsenko's Avatar
grytsenko
Sometimes I do not rely on scanners because my friend tested his car and it turned out to be over 10 codes with problems. They wanted $700.00 for repair. Then his friend tested it and all he needed is o2 sensor. But from my own experience it could be:
1. O2 sensor.
2. Fuel regulator (very possible!)
3. TPS sensor (I had same problem with Mazda)
4. Spark plug wires (sounds weird but my other friend had exact. same problem with Ford and I had it once with Camaro).
Also I would check:
1. Bypass air hose
2. Cap and router
Very often problems can be very minor but they are pain in the *** to doscover...
Old Aug 5, 2006 | 12:26 AM
OmegaESIROC
hmm
Thanks for the heads up
turns out the fuel injector is causing the problem along with the o2 sensor.\
it seems the injector is continuasly spraying into cyl 5 and the cause of that is the computer so my mechanic is hunting down a new comp as i type.
well actually waiting for it as there is a week for delivery from chryster according to him lucky i am not the one paying for it.
