I have a 1990 daytona shelby 2.5l turbo fault code 27
I have already replaced the map sensor & the pick up sensor no change it idles rough and when after about 10 or so min. of driving it will die it will restart after a few min.
code 27 is injector control circuit what is this
thanks
1990 daytona shelby
thanks
1990 daytona shelby
ORIGINAL: 1990 daytona shelby
thanks
1990 daytona shelby
thanks
1990 daytona shelby
A bad injector or wiring to the injector
bad computer...or bad ground to the fuel rail..
if you go on the site www.minimopar.knizefamily.net it will give you all the fault codes and possible cures for them. I am having the problem with 3 4 injector but can not find out which ones they are. try that site it is the best out there that i have found so far.
