Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
Leaking Oil
Old Jul 15, 2004 | 12:12 AM
ovalRacer's Avatar
ovalRacer
Default Leaking Oil
Got quite a gusher under the 86 Daytona. Have narrowed it down to an area near the right axle output drive shaft. Either the speedo or the shaft seal. Being lazy thought I would ask a couple questions before I tore it apart. I replaced the drive shaft seal a couple weeks ago when I replaced the engine. I did not drive the car until a few days ago. When I did I find a large puddle. Narrowed it down to the transmission output, I think. The question I have is this. Has anyone seen oil leaking past the speed sensor? I loose about a 1/3 cup of ail everytime I park it. I suspect the leak is at the speed sensor since I replaced the drive shaft seal. I coulda damaged the seal when I replaced it but I doubt it. Any help? Did not find anything archived that would help.
Old Jul 15, 2004 | 01:50 AM
87Indy500's Avatar
87Indy500
Default RE: Leaking Oil
Did you remove the speed distance sensor? If you did was the O-ring seal in good condition around the sensor?
