Dodge Daytona The G platform cars that are to this day, fun sporty machines that car modding enthusiasts love to get their hands on, the Dodge Daytona and Chrysler Laser.
shifting problem
Old Dec 28, 2006 | 08:59 PM
mongoose_Fear93's Avatar
mongoose_Fear93
Default shifting problem
i have a 92 Daytona and it recently has gotten shifting problems but it only happens when shifting into 3rd and sometime it can take 3 attempts to get into 3rd gear. ant ideas on what it could be would be great
thanks in advance
Old Dec 28, 2006 | 11:13 PM
damageincracing's Avatar
damageincracing
Default RE: shifting problem
I'm assuming it's a manual trans? If so, check your engine mounts and MAKE SURE THEY ARE TORQUED TO SPEC!!! Second, re-align your shift linkages. Been there- done that. If the engine mounts are loose (or loosened and then retightened) it will throw off the trans shift cables or linkages and result in the problem with shifting. It happened to me when I changed engines, only mine was second gear. It would go into gear... almost. It would pop out and grind like mad. I readjusted the linkage and all is fine now. That would be the best bet since you didn't mention anything about difficulties with fourth gear. If that were the case you would have to open the transaxle housing and do some repair work...
Old Dec 29, 2006 | 06:49 PM
mongoose_Fear93
its an auto sry for not specifing that
