97 Neon 2 Dr 5 Spd
i have a 1997 Plymouth Neon, 2 Door 5 Speed for sale
its got just under 140,000 miles on it, I just replaced the water pump and timing belt, brakes are decent, rear tires are good front might need attention soon, runs great, aslo replaced valve cover gasket and o-rings when water pump and timing belt were done, and new plugs and wires, air filter is also not too old
its black but was purple, has cheap black base coat clear coat paint job.
interior is clean
asking $2800 easily gets 35 mpg back and forth to work for me and 40 mpg highway miles sometimes
located in Ohio 45 minutes south of Toledo in Leipsic Ohio
interior is clean
That still sounds pretty high man. Btw, Im down here in lima, not too far from you.
Trending Topics
i know the price is high, i should just keep it, anything less than 2000 and i'm losing money and wont have enough to pay off my credit card after i buy an air compressor, and probly an old truck to drive back and forth to work an old diesel to try alternative fuel methods on
I originally wanted to put some new rims and tires and strut and spring on it and run in SCCA classes in Columbus but its hard to spend the money on that stuff when money is tight and i don't have an air compressor right now and my 96 4x4 Chevy alos needs front axle seals
