2002 neon making noise when turning steering wheel in park
I have noticed for a while that when hitting bumps, the suspension makes alot of noise.
Apparently something is wrong because when the car is sitting, I can turn the steering wheel back and forth and I hear a noise like something is loose (kind of a pop noise).
Checked the lugnuts and the wheel tight. I jacked it up and moved the tire by hand, and there isn't much play if any that I can tell. I put a crowbar under the tire and there was no play up and down.
I was wondering if you all had any ideas of what it could be?
ORIGINAL: shelbyzman
Thanks for the info.
The only thing is that the sound, sounds more like metal piece that is loose. It sounds like the noise is coming from around where the tie rod is....main reason I'm not sure if is the tie-rod is because there isn't any play when I jack it up and move the wheel.
thats how u test a wheel bearing... grab the tie rod its self and try to twist and turn n move it, it shouldn't move and neonon19's if ur car wasn't so freaking hot i'd say ban for 1 month for the sig lol
