Cold Air Intake and KN fliter?
Hi i just got my cai today and i finish installing it but i have two questons? 1. Is how do you guys put the sensore on the tube because the rubber gormet fell off and now the sensor doesn't fit? 2. I got the KN filter rc-9630 from amazon.com, do i have to oil it before i drive my car or does it come pre-oil? I will post pictures when i get everything finished under the hood. Here is the cai i order from ebay http://cgi.ebay.com/ebaymotors/00-01...spagenameZWDVW Thanks
When I did my turbo I just drilled a hole in the back side of the filter. I would try and drill out the pipe a little and stuff it in there with some rubber support. If not your check engine lite will come on and off. Good luck.
you can't put the rubber thing back in? I wouldn't drill anymore holes. I would do the electrical tape thing if you can't get the rubber thing back in. I had to really lube my sensor to get it in the rubber gasket thing too.
Yes, that is K&N's universal cone filter, and it IS pre-oiled.
As far as a lack of a gromet, you could also just drill the hole and use a little bit of silicon to seal it and hold it there... just a little bit, I think I don't have to explain how careful you should be of where not to goop it on to.
