Windshield squeak
I also had a rattle/squeak coming from the front passenger side. It turned out to be the hood rubbing against the plastic block that is just to either side of the adjustable hood stops. I found that if i pushed lightly on the side of the hood it squeaked. I adjusted the hood stops, placed weather stripping on the plastic blocks next to the hood stops and shot some wd40 around the plastic blocks. No more squeak/rattle. I would post some pixs, but my digital camera died last week. Not sure this will correct your problem, but it did for me.
Trending Topics
Nope not a hiss.
I just got in from work and it didn't creak on the way home. It did going in. We'll see. It's raining now and nothing is wet so it doesn't appear to be leaking.
To be continued...
To be continued...
I understand it was a simple repair, but they are going to work for every cent I spent on my truck.
the warranty should cover this. It was just easier for me to fix than go to the dealer. I most likely will have them check any issues out when I take it in for an oil change.
