Parting out 1986 dodge truck!!
have a 1986 dodge 3/4 ton 2wd with a 360 and 4 berrel carb on it i am parting out. Truck ran fine and drove perfectly. i gave up on it as i just cant use 2wd trucks anyway so now i am going to part it out keeping few assorted little things almost everything is for sale just give me a call with offer and what you want engine runs good and truck shifted beautifully just was not much of a mud runner like i thought it was. This truck is apart and by aprat i mean i have every single part off and sorted in my yard i took care to not harm or brake anything so everything is good.This truck was almost rust free any place you think dodges rust out this one most likely is soild as day she was built. Need to get rid of as much of this thing as i can as fast as i can so mom does not kill me for junk in yard Haha. Please call 740-504-1819 ANYTIME i do not use email and will not respond and if i do not pick up please leave a msg im in collage and most likely in class i WILL get back to you soon!!!!!
I Still Have The following!!
360 engine ran good carb on it needs rebuilt new fuel pump and oil pump on it 250
Truck Cab very little rust no back window 200
Stering colum 65
Stock rims with stock hub caps excellet shape 100
Wireing harnesses for Dash 35
Tranmission 727 2wd Automatic shifted perfect with torque converter 150
Doors totaly rust free 100 Each
Mirrios one without glass 10 <br
Bumbers front one is bent 75 each
Dash parts all working none broken and all have good crome on them make offer
Bench seat ripped on driver side and missing padding 20
Fenders 50 each very soild surface rust on them
Hood 150
Frount inner Tubs 45 each
Grill head light holders grill brakets and radiator holder 125
Radiator 21in deep 3 core no leaks and good condition extra large for towing pakage with tranny cooler 125
Gas tank 50
Drive shaft 25
Rear axle chyslar 9.25 with 3.54 gears 150
Brake boster and master cylinder 25
Frount sespension and tie rods 125
Frame very very soild still has factory primer most spots 200
Main springs 5 springs light duty 3/4 set 125 for both
Gas tank filler neck 10
Ac and heater fan 20
Tested and working starter 25
Tested and working ulternator 45
Truck bed (not one pictured) Recently repainted long bed in good condition no tailgate fenders are just stating to rust out fixable though floor is soild some bends in underside skirting priced fairly 225
Some prices are negotible
Stering colum 65
Hood 150
Gas tank 50
Drive shaft 25
