Notices
360 Magnum hughes camshaft, springs, crower pushrods+other parts!
Old Mar 15, 2010 | 12:27 AM
billytuffnuts's Avatar
billytuffnuts
Default 360 Magnum hughes camshaft, springs, crower pushrods+other parts!
360 Magnum Parts...
Hughes HER1828AL Roller Camshaft - $150
Camshaft Technical Details
Intake Valve Lift 1.5
Exhaust Valve Lift 1.5 .510"
.510"
Intake Valve Lift 1.6
Exhaust Valve Lift 1.6 .544"
.544"
Intake Duration at .050"
Exhaust Duration at .050" 218°
228°
Lobe Separation Angle 114
Intake Opening at .050"
Exhaust Opening at .050" -2° BTC
51° BBC
Intake Closing at .050"
Exhaust Closing at .050" 40° ABC
-3° ATC
Min. Suggested Cylinder PSI 165
Sweet Spot RPM 2300 - 6100
Hughes 1102 Valve Springs $65
# Installed Height/Pressure: 1.750"--135#
# Pressure @ .450" lift: 280#
# Pressure @ .500" lift: 300#
# Pressure @ .550" lift: 315#
# Coil Bind: .600" lift
# Outer Spring ID/OD: 1.068"/1.465"
# Type of Spring: Single w/ damper
16 Crower 6.950" length .080" thickness 5/16" pushrod set with ball/ball ends and drilled for oiling - $75
Mopar Performance Polished Magnum Valve Covers - $150
Decent shape, has some wear and tear but should clean up nice.
Hughes 8* Adjustable Timing Chain - $75
Advance or retard your cam 2-8* degrees
Above parts have about 3000 miles on them. I bought them from another member and ended up not using them.
Stock Magnum Pushrods, valvesprings+retainers, and camshaft - 25+shipping
These came off a 98 5.9L 360 with about 75k miles on it. No issues whatsoever.
Stock 5.9 Magnum Valve Covers - $10.00
Has some overspray on them
Stock 98 5.9 Magnum EFI Kegger Intake Manifold and Injectors/Rails - $40.00
Also has some orange overspray
Autometer Autogauge 2 1/16" Mechanical Water Temp Gauge+pod - $20.00 shipped
I had this hooked up for maybe 30-60 minutes. Works fine just don't need it.
All prices are plus shipping unless otherwise noted. All prices obo, I can take additional pictures so let me know if you need any more. Located near Chicago, IL
Old Mar 16, 2010 | 07:32 PM
billytuffnuts
bump.
Old Mar 18, 2010 | 01:48 AM
billytuffnuts
bump.
Old Mar 18, 2010 | 06:52 AM
wewanaplay's Avatar
wewanaplay
I may be interested in some of your parts, Where are you located?
Old Mar 18, 2010 | 05:31 PM
billytuffnuts
located in Chicago, IL
Old Mar 19, 2010 | 06:54 PM
billytuffnuts
help me help you
Old Mar 24, 2010 | 06:04 PM
billytuffnuts
make offers
Old Mar 26, 2010 | 08:28 PM
billytuffnuts
listed a bunch of the parts for sale on ebay
http://motors.shop.ebay.com/chache87...1&_from=&_ipg=
