funny noise on my truck
ever since i changed my oil a few days ago, when i shut off the truck it makes this squeeling noize for about 5 seconds. low pitch constant sound for about 5 seconds. what the hell is that?
Let's think this trough. Turn engine off then noise begins
-can't be a belt, engine is not turning
Could it be that you used different weight oil and the lifters are making sounds? maybe the MDS system? probably not
My guess is that it is vacuum related and the noise is coming from under the dash and one of the vacuum controlled actuators (vent/AC) is either noisy or leaky as it returns to the detent position
Ooh, good call. That noise bugged me until I figured out what it was.
Trending Topics
its not the radio, its too loud and i dont have a ren or rer.
oil was same weight.
but everytime i do get out i have some water on the ground from the ac, but not too bad, and its been doing that always.
it didnt make the noise today, weird
Could it be a fan staying on under the hood? If it is hot enough I know the fan comes on on it's own if electric. I believe we have both? Now I have to look tomorrrow when I change my stupid reverse cmos from the front to a ccd the is not for reverse only, has a jumper on it for front use. I put the rear on tonight, wow night looks like day.
Sorry back to your sound, we have to figure out what stays on when you turn the key off, I know a lot of stuff clicks and moves and noises under the dash, just the truck shutting down I always figured, doesn't keep going. stops right away. I don't think it is a problem but if it is repeatable take it to the dealer.
sometimes the sound is immediate after i shut it off. the other day i parked it, opened the hood, than turned it off and nothing. waited 15 sec and shut the hood. right when i did that, the bastard sound starts, so i couldnt see where it came from. ill try this again today and get back to you. thanks man
