Track on/off, ESP/BAS and ABS lights come on
I have a 2010 RAM 1500 with less than 40K miles after a recent oil change I noticed when making a slight right turn and accelerating I heard a ring and then noticed 3 dash light on, trac on/off ESP/BAS and the ABS light. The lights turned off after 1 minute or so then it would only happen every now and then but now it is a little more frequent and I also noticed earlier that my gear will automatically go from the D positon to 4th gear on its own. Has anyone had this issue or any advice before I even consider taking it back to the dealer. Thanks is advance
have the dealership check your speed sensors, i had the same issue and it was a break in one of the wiring harnesses for the speed sensors. i cant see how an oil change would have caused this, unless they dropped something on the harness when removing the oil filter.
go to dealership, find out what sensor is causing the problem, if its the passenger side, and the dealership does not warranty it, then present the bill to the place that did your oil change. if you did the oil change yourself, give yourself the bill
