2012 longhorn payload?
hey i'm looking at upgrading/downgrading from my 07 2500 hemi to a 1500 long horn but am not having much luck in finding the payload of the long horn. one site showed 1100lbs is this right? does anyone know if you can get the long horn with max trailer tow package, i'm not concerned about the trailer weight but the actual payload of the truck. any info would be great
wow...I would think that the longhorn would be one of the better 1500s for payload...seems the sport is the best..not even the laramie has that. Are they just not equipped with the same towing packages?
Why is that ridiculous? The CTD probably weighs 500lbs more than the Hemi... it is not like they built a new chasis for the CTD. They both use the same basic equipment have the same basic GVWR but the cummins weighs more empty so has a lower payload capacity (GVWR-curb weight = payload capacity)
The biggest difference here though is that Dodge rates the Ram to be able to tow 14,400 lbs. with a Hemi and 15,500 with a CTD, only an 1100 lb. difference. A Ford F250 by contrast is rated to tow 15,400 lbs with the 6.2 gas engine and 22,700 lbs. with a 6.7 PowerStroke which is a 7200 lb difference. Much more believable.
I think rating a Hemi at 14,400 lbs. is a joke, personally. I have the engine and have no complaints but because it makes too much of it's power too high in the rpm band, it's not an ideal tow/haul engine...
Trending Topics
Rob
