Uneven front bumper.... I'm speechless!!
While having a dealer fix an unrelated warranty issue, I pointed out that my front bumper was uneven.
The driver side is about 3/4" to 1" lower than the passenger side. It is most noticeable at the trim piece, just above the bumper. I noticed it while waxing my truck when it was about 1 month old. There is no damage, it obviously was delivered that way.
The service writer said he'd have the body shop look at it and fix it.
He called me a short time later, sounding rather embarrassed. He said per their body shop manager, the front bumper is not adjustable...... WHAT?!
He was told they can only adjust it so that the right side is high......... or the left side is high........ they can't make it even.......
He then said he was told that the general manager's truck has the same issue as mine, only the gap is bigger. He said they couldn't adjust his either....
I said, "So you're telling me I just have to live with an uneven front bumper?" He said, "Yes, isn't that crazy..?"
Really...... they cannot adjust a front bumper....?! Does that mean all the 2013 bumpers are uneven......?!
I am speechless......................
Thats a manufacturing fault, that should not be your problem to live with. Unacceptable QC on Ram's behalf on both the managers truck and yours. Lack of discipline of the manager for not addressing it sooner.
A new truck should be damned near perfect in this day of manufacturing tolerances.
I'm going to wait until another minor warranty issue is fixed and then I may write a few letters to Chrysler corporate.
I want to tell them how difficult they are making a Dodge Truck fan justify ever buying another Dodge Truck....
That's bull****. I've "hurt" my front bumper a couple times and fixed the slight problems myself so I've been under the truck and seen the brackets. The bumper has two main brackets and those could easily be worked on to adjust the bumper. I think your dealer is just trying to get out of fixing it. If they won't make it right find another one or call Dodge. Good luck.
If you're referring to the metal/chrome part of the bumper then ignore this. If you have a Sport or are talking about the plastic piece above the chrome then read on...
When I was installing HIDs on my new 1500 I noticed something like that. Turns out the plastic front bumper cover was not seated into one or two of the holes in the frame. That caused it to sag and have a gap above it. It was a very simple process to just push the darts into the holes and reseat the cover the way it was supposed to be. If your issue is with the plastic cover this may be a simple resolution.
Rob
Rob
Trending Topics
Rob
Sadly, mine is a chrome front bumper that is uneven. The plastic trim piece above the bumper appears to be straight and true.
There is plenty of slop in the mounting holes on the chrome bumper. I know because when I put on my tow hooks I put the bumper back on crooked
Try not to get too dramatic about this, I mean jeeze if you didn't notice it when you bought it how bad could it be.
It's also quite possible a fastener has come a tad loose and allowed the bumper to slip down. Bumpers aren't light, you know.
